quali,s 1080ir firmware update
Discussion in 'General TV Discussions Forum' started by debris, Oct 11, 2004.
  1. debris
    debris
    It,s a promising positive step forward the new firmware v 2.59 update.But on dvi aspect nothing new. it is still doesn,t cover The majority of Plasma screens and LCD DVI requirements.The otherwise nice receiver again has a fixed dvi output {28/49,8} not working with Pio plasmas!! Any comments please?
  2. GMeijer
    GMeijer
    Hi Debris,
    What Pioneer screens are you using?
    BR Gerard.
  3. debris
    debris
    Hi Gerard , thanks for response
    i,m using CMX 433 furnished with pda 5002 card.
    Is there any solution?
  4. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    Hi debris,
    Your 433CMX with PDA-5002 will not accept 720p and 1080i signals on the DVI input. You would need to replace the card with an Aurora A304-HDCP. Hope this helps.
    Steve
  5. debris
    debris
    Thank you Dutch
  6. Murco
    Murco
    debris - I'm interested in watching 4:2:2 feeds tv (I'm thinking of buying this machine) I believe there can be a problem with slight interference with a "normal" tv at the bottom of the screen, do you know if this has been cured with the new update?
    Many thanks for your help M
  7. Hellicopter
    Hellicopter
    Jan 26, 2002
    331
    +5
    Sorry but no change in 422 but it is very watchable despite the slight problem.
    Alan
  8. Murco
    Murco
    Thanks for your reply Hellicopter. M
