Quake set-up
Discussion in 'Subwoofers' started by irvind, Dec 27, 2004.
  1. irvind
    irvind
    Dec 6, 2004
    42
    Glasgow
    How best to set this up? Got hi and lo level connections. The manual could be clearer I think, it doesn't mention which to set first.
    Any clear step-by-step guide?
    Thanks in advance!
  2. Malky1903
    Malky1903
    Jul 2, 2003
    1,937
    48
    Aberdeen
    +64
    I have mine set to position 2 and connected via low level only. Use hi level if you have a Neutrik connector and leave it at 0 if not connected. If connecting via low level only, adjust the low level volume to your desired position. Crossover is set depending on which speakers you are using. Or set it to 0 and let the amp deal with the crossover [normally 80hz on the amp]
  3. irvind
    irvind
    Dec 6, 2004
    42
    Glasgow
    Thanks Malabbey,
    I do have the Neutrik doofer, will set up one at a time I guess, unless there's a better system... Seems to me that letting the amp set the crossover would be a good thing, so I'll try that knob at zero and see what happens.
  4. Kenny Glasgow
    Kenny Glasgow
    Apr 1, 2004
    3,348
    Livingston, Scotland
    +227
    Irvind
    I have my Quake connected to a TAG AV32R and let that do all the work. I used a SPL meter to help fine tune the settings on the Quake. It cost around £30 and is worth the investment. Each room will be different
  5. irvind
    irvind
    Dec 6, 2004
    42
    Glasgow
    Understand that, an SPL meter seems like a great plan. Cheers.
