Quadscan Pro Vs Quadscan Elite ??
Discussion in 'Projectors, Screens & Video Processors' started by gizlaroc, Jan 22, 2002.
  1. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,217
    Norwich
    +819
    as the topic says what is the difference??
    I have a quadscan pro at the momement and was wondering what the difference is with the Elite version.
    I have read through the specs of both and cannot see a difference.
    am i missing somthing???
    my projector is having trouble syncing when i put a pal signal into the quadscan.
    it is a plus dlp svga but i can only get the right image with PAL material when i set the quadscan to vga.
    any ideas??
    thanks
    Guy
