Quadscan Pro V Iscan Pro???
Discussion in 'Projectors, Screens & Video Processors' started by diesel, Dec 18, 2002.
  1. diesel
    diesel
    Feb 2, 2002
    736
    West Yorkshire
    +58
    Is a focus enhancements quadscan pro better than an Silicon Image iscan pro?
    I have a panny plasma and a sony 10ht pj (not yet set up). I currently connect dvd via component to iscan, sky+ via svideo and vcr via composite. These are then connected to the panny via the 15pin to 15pin d-sub so that I can use my Xbox to connect to the YUV connection on the panel
    Would an quadscan do anything superior to the iscan?
    sorry if this is a bone question, I'm relatively inexperienced about these things but was reccomended to buy the iscan when I bought the PJ (used)
    thanx
    Andy
  2. diesel
    diesel
    Feb 2, 2002
    736
    West Yorkshire
    +58
    anybody?:eek: :confused:
  3. Gordon @ Convergent AV
    Jul 13, 2000
    14,218
    +3,073
    For your purposes the Quadscan would make the image worse in comparison to the Iscan.
    If you want a significant improvement then save for a CS-1 from Focus or something even better.
    Gordon
  4. diesel
    diesel
    Feb 2, 2002
    736
    West Yorkshire
    +58
    Thanks, One came up cheap an I was tempted but now i know not to bother:)
  5. Steve1138
    Steve1138
    I did an evaluation of the iScan with a 32" LOEWE TV with VGA module fitted.
    It was great.
    The only downside was it's inability to handle aspect ratios not equal to 4:3 or 16:9.
    The CS-1 would give you the required scaling capability needed to overcome that for different aspect ratios...
    So I'm holding off for a while longer and planning to build a HCPC with a Holo3Dgraph card to do the de-interlacing AND scaling which will keep my options open for both a LOEWE TV and a projector (either for CRT (with VGA) or DLP (with DVI output on the graphic card)
    www.immersiveinc.com
    Steve
  6. museumsteve
    museumsteve
    Jan 28, 2001
    8,003
    4
    Nth Hampshire
    +1,109
    what is the Quadscan good for then.?
    I have an Iscan which I use for PAL sources (DVD, Sky etc) and currently put NTSC DVD/consoles via progressive into the HS-10. Would a Quadscan benefit my NTSC sources at all.?
  7. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,421
    Norwich
    +934
    have a look at the thread i just started about the new centrestage, looks like it could do the job nicely.
