Quadscan Elite or P-scan DVD
Discussion in 'Projectors, Screens & Video Processors' started by magking, Jun 14, 2002.
  1. magking
    magking
    Jan 6, 2001
    380
    Norway
    Halol.
    I've ordered a Panasonic PT AE-100, and wonder if i should get a Progressive scan DVD, a Iscan Proor a used Quadsvan Elite.
    The used Quadscan Elite is £1100, and that means i have to keep me Denon DVD 3000 with no DTS and no component output for some months.
    Or i could get a P-scan DVD like the Philips 962 from Hong kong with P-pal and P-ntsc.
    Everybody seem to say the VGA input is better, that would be easier with the Quadscan, right? Will the quadscan be a overkill, i could get a new Iscan pro for £900 woukd that be a better choice?
    What to buy and how to connect thats the question, when i decide what to buy i'll know how to connect.
    Many questions, I know.
    Any respos appreciated.
  2. richard plumb
    richard plumb
    Jan 27, 2002
    14,495
    Windsor
    +1,051
    consider also the ProV (do a search, there are some threads here already). Depending on the quality you require, it may fit your requirements well, and its only around £150.
  3. Gordon @ Convergent AV
    Jul 13, 2000
    14,214
    +3,057
    Should also point out you can buy new Quadscan Elite's for well over £100 less than the price of your used one!
    Magking....are you outside UK as new Iscan's are £650ish....
    Gordon
  4. JSW
    JSW
    Feb 21, 2002
    4,284
    Staffs
    +333
    Think he is from Norway somehow :clown:
  5. Gordon @ Convergent AV
    Jul 13, 2000
    14,214
    +3,057
    Yeah....I notice now. When I pressed to reply and started typing I looked down at previous posts to see if he was outside UK and none of that info is shown.... I'm not usually that thick....
    Gordon
  6. magking
    magking
    Jan 6, 2001
    380
    Norway
    Sorry my late answers, have been away for the weekend.
    I have considered the Iscan Pro to, new price here is close to £1000.
    Maybe I should buy a Iscan from UK, any ideas to were to get it?
