Quads with A/V
Discussion in 'Home Cinema Speakers' started by PEZ, Nov 10, 2003.
  1. PEZ
    PEZ
    I've recently bought the Denon AVR-1804 and was wondering if it's OK to run a set of Quads with it. Since they are 8ohms and only 87d sensitivity I'm a bit worried.
    Perhaps you are thinking that they aren't right for an A/V setup?
    The thing is I can get them cheaper than what they sell for in England. I'm looking at the Quad 11s and 12s. A centre speaker would follow.
    However I have tested the Acoustic-Energy 3B evo and found them pretty good indeed. I also had a quick look at the Monitor Audio's bronze 4 system...any good with the Denon?
    Thnaks in advance:smashin:
  2. Noodle
    Noodle
    Jan 6, 2003
    577
    Peterborough
    I'm sure the Denon will run them just fine.
    Why not just buy the ones that sound best.
  3. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    I had a demo with my Denon 1803 and the Quad 11Ls and it was OKAY driving them. Not as successful as a specialist Stereo Amp but it did the job (however I only used this in 2 channel mode).
    Noteworthy that the poweroutput of the 1804 will more than halve upon driving five or more channels - can't see it posing too many problems though.
  4. pstables
    pstables
    Dec 4, 2002
    58
    Rossendale, Lancs, UK
    I'm running a pair of 21L's with an L centre from a Pioneer 2011 and it drives them no problem at all.
    Very happy with it.
    Paul
  5. PEZ
    PEZ
    Thnaks for the input, I'll audition them with it!
  6. zoolander
    zoolander
    The Quad L range are fine musical speakers but on a sound per pound basis there are better alternatives out there,especially at AV package level.Say you were just after a nice stereo setup that looks class,a pair of Quad 11Ls would be great but for that price you can fetch a nice set of Kef Q series package-the AV7 which retails at £1300.The package consists of the Q7 fronts-top of the Q range and were rated very highly in magazines,Q1 rears,also well reviewed,QC centre and finaly a PSW2000(?)This set up will be a better bet for both AV and AV use as there is plenty more bottom end welly.Also,the Quads require a decent stereo amp to sound good with music,so will need at least a £800 AV reciever to do them justice.
    zoolander:D
