Quad LNB does it degrade the signal
Discussion in 'Satellite TV, Sky TV & FreeSat' started by meansizzler, Aug 18, 2005.
  1. meansizzler
    meansizzler
    May 11, 2005
    7,892
    104
    London
    +343
    OK I'm going to fit a Quad LNB to my sky digital dish, but will it degrade the signal, I have 60% signal strength on a signgle LNB does this mean I will have 60% signal strength on each of the boxes connected to the quad LNB or will it half...
  2. Archie Fax
    Archie Fax
    Nov 23, 2003
    233
    Kent
    +10
    No it won't degrade the signal. But as it is heavier than the single lnb, the extra weight might mis- align the dish very slightly (in theory at least). So check the signal quality after the installation.
    I think I'm correct in saying that if its less than 40%, then you might have problems.
  3. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Try to get as high a reading as possible. 40% will work OK, but if you are getting 40% on a day where there isn't a single cloud in the Sky, the signal will probably drop to 0% during a heavy rain shower, and you'll lose the picture.
  4. SamRadford
    SamRadford
    Jul 12, 2005
    3,965
    103
    N. Yorkshire
    +308
    Some good info about replacing your LNB on this page.
