Quad L Subwoofer - Opinions and prices?
Discussion in 'Subwoofers' started by andyasb, Oct 27, 2004.
  1. andyasb
    andyasb
    Jul 27, 2004
    126
    Surrey
    +12
    Hi all,
    I'm using AVR300 with Quad Ls 12 / 11 / centre, and a very old REL Q100 subwoofer. I was thinking of changing for the new matching Quad subwoofer, has anybody heard it in action? What kind of deals are people getting?
    ta!
    andy
  2. recruit
    recruit
    I'll probably hear it at the What hi fi show, but i am sure it will be a good sounding sub, i'll try and give my opinion if i get to hear it.
    John
  3. Kazman
    Kazman
    Jan 14, 2004
    5,349
    Luton, Bedfordshire
    +142
    It's supposed to be fantastic, I think it won the sub woofer of the year award for its price bracket in the What Hi Fi awards this month.
    It is worth it for the finish alone :D
    In fact, you will end up with the system that won What Hi Fi's PRODUCT of the year in that category!!! :smashin:
    I should be getting my Quad 21L's in the next few days, looking forward to them :) The L Centre is lovely. Have to get some Marble slabs or some sort of isolation platform though, as I can't have the spikes on the laminate floor :eek: What finish have you gone for? I decided to go for the Rosewood finish.
  4. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,183
    2
    +3,638
    2p coins are a slightly cheaper (and more discrete option) than the slabs if you want.
  5. Kazman
    Kazman
    Jan 14, 2004
    5,349
    Luton, Bedfordshire
    +142
    Good point mate, forgot about the old 2p coin method :) I'll try that first before shelling out on the marble :) :D
  6. NMyTree
    NMyTree
    Jun 17, 2004
    105
    16
    Yankville, Whanker USA
    I was told that marble wasn't a good option, because it causes a high frequency resonance.
    Anyone else ever hear that, or know if it's valid?
    The same person suggested Slate be used, instead of marble or granite.
  7. Roam
    Roam
    Yeah! Marble is no good on it's own as an isolation platform. Your speakers will move around on it slightly with it having a polished surface better to use something that will hold the speakers more firmly. I used it under my sub and found it cuts down on the bass weight for the very same reason, spiked or otherwise (especially spiked). You could I suppose cut some rubber matt to fit, that may help.
  8. Kazman
    Kazman
    Jan 14, 2004
    5,349
    Luton, Bedfordshire
    +142
    Fair enough, looks like marble is out :D What about those isotek isolation platforms that have been talked about? I might try to source some rubber mats and cut them to shape if all else fails.
    I told the wife about the 2p idea, and she gave me 'the look', don't think she is keen having 2p coins on the floor :D 2p coins != WAF
  9. Roam
    Roam
    Don't know about the isotek's but how about good old blue tack! Stick a packet under each speaker. I don't fancy your chances of moving them again without some Weetabix though.
  10. cameronl
    cameronl
    Aug 13, 2002
    1,217
    38
    +11
    i have Quad 12L & center in maple and imho it looks lovely :)
    I too am interested in finding out about the sub.
    CaM
  11. recruit
    recruit
    My mate has decided to buy the Quad package featured in the What Hi Fi awards so will defenitely give that setup a good grilling, i am sure it will sound excellent
    John :)
  12. fama
    fama
    Jan 28, 2002
    142
    is the package 12L L CENTRE 11L +SUB?
    Is this being sold as a package at a discount price or is it just a question of
    buying individually?
    what support/feet does the L centre have?
  13. Kazman
    Kazman
    Jan 14, 2004
    5,349
    Luton, Bedfordshire
    +142
    The L Centre doesn't come with any feet, they supply it with four small rubber stick on pads, which should be effective enough, unfortunately, the depth of my TV isn't big enough to enable use of these, so I had to use sticky pads to stick it down properly without fear of it falling off :eek:
  14. pstables
    pstables
    Dec 4, 2002
    58
    Rossendale, Lancs, UK
    Hi All
    I've had a set of 21L's and L centre in maple for over a year now and more than happy with them.
    I currently have a Paradigm PW2200 which is a bit of a beast and a bit ugly in black - I'm very interested in the L Sub in a nice maple finish.
  15. Kazman
    Kazman
    Jan 14, 2004
    5,349
    Luton, Bedfordshire
    +142
    I'm sure you would get a discount if you bought the entire package from one place, but I doubt you will find many dealers advertising the fact, Quad, like many other manufacturers and suppliers tend not to allow mass discounting of their products openly by dealers, just like Velodyne do in the UK right now.
    Negotiate with a dealer and just plain ask them, what is the best price you can do for me on these speakers, if they want your business, they will play ball, although you do get some who will just refuse to haggle, there are always one or two diamonds out there who are more than willing to get the sale for a tiny loss on their margin.
  16. russraff
    russraff
    Aug 1, 2000
    2,409
    Newcastle
    +63
    Sevenoaks have this package for just under £2k. I am not sure if this is any saving, though.
    Russell
  17. recruit
    recruit
    Russell i think that the RRP is about £1930 for the package which is quite a bargain considering what you get :)
    John
  18. fama
    fama
    Jan 28, 2002
    142
    THANKS
    I have infact picked up second hand a quad 11L pair and quad L centre.
    I bought subsequently another 2 new pairs quad 11L one for my brother
    and managed to get a substantial discount.Ive ordered an svs sub but still would be interested in the quad sub.I'll ask the dealerer if hes got it.
  19. Kazman
    Kazman
    Jan 14, 2004
    5,349
    Luton, Bedfordshire
    +142
    Well done mate :), you will love them, the Quads are great, I'm loving my 21L's right now, amazing speakers!!
  20. recruit
    recruit
    Fama what SVS sub have you gone for? if you don't mind me asking.
    John
  21. Dfour
    Dfour
    Jan 19, 2004
    4,088
    71
    Bracknell
    +86
    From seeing then Yesterday at the What hifi show they look and sound fantastic:)
  22. recruit
    recruit
    Dfour i am going tommorow did they have a Home Cinema setup for the Quads?
    John
  23. Dfour
    Dfour
    Jan 19, 2004
    4,088
    71
    Bracknell
    +86
    Yes they did have in the What hifi section. Such a lovely sound and finnish on them :smashin:
    The setup you REALLY need to see is the Arcam room.If you thought you have seen hifi kit you aint seen nothing till you seen all of theres. It was absolutely jaw droppingly :eek: awesome. :devil:
  24. recruit
    recruit
    Excellent Dfour, i am looking forward to it :smashin:
    John :)
  25. Kazman
    Kazman
    Jan 14, 2004
    5,349
    Luton, Bedfordshire
    +142
    The Quad setup was in the What Hi Fi section of the show, I was VERY impressed with the Quad sub, it destroyed anything I heard in the REL room, and was one of the best sounding sub's at the show.
    The Genie MS409 sub was also very impressive.
    I can see why the Quad sub won the best sub in its price bracket award though, fantastic bit of kit!!
  26. Tejstar
    Tejstar
    Dec 4, 2002
    22,794
    London
    +1,080
    Completely agree 100%. The Quad subwoofer, for me, was one of the highlights of the show. It was so tight and controlled and as always a beautiful finish from Quad.
    I was only a little disappointed that they couldn't really test it to full potential. They were showing SW: Empire Strikes Back (the whole movie!) so obviously there were quite a few scenes where there wasn't too much happening. I stuck around though for the light sabre battle at the end and it sounded awesome. :D
    The 12L/11L and centre are great but the subwoofer pushes the package to another level. I can see now why it's winning quite a few awards as a stand alone product. Very highly recommend :thumbsup:
  27. pete0
    pete0
    Apr 4, 2004
    42
    +3
    If you're still looking to fix your spike problem you could take a look at some of the stuff here...
    http://www.hifibitz.co.uk/subcategory.asp?id=42&srchoption=2&manid=0&pagesize=10
    more likely to get WAF !
    Looking forward to hearing the Quad sub, currently running 22Ls for stereo duty via Quad amp with an L-centre for HC so I reckon the new sub should fit right in, if I can find somewhere to put it...
  28. fama
    fama
    Jan 28, 2002
    142
    Unfortunately nothing is set up as i was hoping to
    move house over next months.I went for budget svs pb10-isd
    so I have 2xquad 11L ,quad centre, yamaha rx750 rec.and rotel 985
    power amp all in boxes save one pair quads for hifi
    as an aside Im currently mucho enjoying a CAYIN mt12 valve amp(quad 11L ,pioneer pd s707 cdp) hifi setup
    fantastic build and sound for the money.
  29. Lester
    Lester
    Mar 4, 2001
    243
    Oop North
    +10
    A friend of mine just purchased the Quad L subwoofer because, wait for it..... it matches his shiny new Pioneer plasma. :D
    Fair enough, for £700 he knew it wasn't gonna sound like a dog. But we both weren't prepared for how it's totally transformed his setup. This is a seriously impressive bit of kit and I would urge anyone to put it on their list of subs to demo. It's only been on for the last few hours so can only get better once it loosens up. Awesome.
    As we unpacked it, his interior designer jokingly commented that such a lovely looking beast deserved to be handled with gloves. And we all chuckled..... until we opened the manual and a pair of white cloth gloves fell out ! Superb.
  30. Kazman
    Kazman
    Jan 14, 2004
    5,349
    Luton, Bedfordshire
    +142
    The Quad L Sub is lurrrrrrvley :D :smashin: And the finish is fantastic, just hope the wife never see's or hears one, she might make me swap my SVS PC Ultra for one :rolleyes:
