Quad L Speakers FAQ
Discussion in 'Home Cinema Speakers' started by Shin Akuma, Mar 19, 2005.
  1. Shin Akuma
    Shin Akuma
    Dec 29, 2004
    2,878
    71
    +90
    I have used big speakers in my little room for movies, now I want to try speaker with single bass driver. My other choice are B&W 705 and PMC TB2 but since both of these aren't closed box design my first choice is Quad L in disgn respect. Today I feel like this is my first day in AV land because I never used this Make before. So here is My FAQ.
    1) Where does this Make stands in Build Quality and Performance compare to B&W and Kef.
    I will appreciat your help Guys. cheers.
  2. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    Quad L are excellent and first rate sound quality and construction but no closed box either...
  3. Londondecca
    Londondecca
    Dec 21, 2003
    2,081
    +96
    Why do you not want a reflex designed speaker
  4. Shin Akuma
    Shin Akuma
    Dec 29, 2004
    2,878
    71
    +90
    Becuase I think sealed box gives better slam and reflex design increase boom in my room, well it is based upon my past experience.
  5. Londondecca
    Londondecca
    Dec 21, 2003
    2,081
    +96
    To answer your original question, the Quads build and finish are great for the price and they also sound great. Are they better than the B&W etc, it depends on your ears.
    Falp is correct, the Quads are reflex speakers.
  6. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    And with two holes in the back, even the Bookshelf models...
  7. Shin Akuma
    Shin Akuma
    Dec 29, 2004
    2,878
    71
    +90
    You Guys are right, they do come with holes. cheers.
  8. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    But if room size is an issue, front port is better than rear port... so are bookshelves over standmoundters.
    However I heard the Quad 11L and I think 20 to 30 cm from rear wall are OK...
  9. wannabeav
    wannabeav
    Have to agree with Falp on this, I have a pair of 11L's on stands and theyre 20cm from the wall. Bass is not boomy at all and clarity is excellant. Have to say though the 11's arent really big on bass so if you do want a bit more slam the12's might be better. The finish on them is also the best I saw at that price.
  10. NinjaKi11a
    NinjaKi11a
    Sep 7, 2003
    314
    16
    Without a doubt.
  11. Smurfin
    Smurfin
    Aug 13, 2002
    21,421
    +4,353
    Don't discount the PMCs...stunning sound for the money imho:) (but different to the Quads)
  12. Shin Akuma
    Shin Akuma
    Dec 29, 2004
    2,878
    71
    +90
    Matt, Do you think PMC speakers are more puchy then Quad, which one do you think would be better for movies. cheers.
  13. Smurfin
    Smurfin
    Aug 13, 2002
    21,421
    +4,353
    I've only heard the Quads once to be honest; I liked them, but a little laid back for my tastes. I would imagine that if you heard them side by side you'd find the PMCs more aggressive, but don't be mistaken, by aggressive I don't mean "rawer"...they are very smooth speakers, with a superb treble. Put it this way, as soon as I'd heard them I decided those were the ones for me:)
    That said, I've just been offered a stonking deal on some new B&W Nautilus 805s:eek:
  14. recruit
    recruit
    Get the B&W 805S they are amazing!! ;)
  15. Smurfin
    Smurfin
    Aug 13, 2002
    21,421
    +4,353
    How did I know you were going to say that!;)
  16. recruit
    recruit
  17. rozzar
    rozzar
    Sep 29, 2002
    1,055
    41
    Braintree
    +23
    the signatures may be good but the standard ones are very lacklustre sounding imo. some 5 year old Jamo Concert 8s filled the room with a much more musical and lively sound at a third of the price
  18. recruit
    recruit
    Yeah but i was talking about the new ones which are rather special.
  19. Druida
    Druida
    Last week I listened at home the Quad 12L and sound clean and warmth,
    its bass was simply prodigious: fast and controlled,
    its treble was clear and clean, with amazing clarity and detail, with a amazing recognize the beauty of instruments and almost perfect with vocals
    The imaging was executed with precision and there was good depth to the sound stage too,
    by this I´m going to buy it
    I´ll buy a NAD 763 for they too
    Greetings
  20. milpai
    milpai
    Mar 30, 2005
    23
    Hi Druida,
    Did you listen to the Quads with the NAD 763? I am deciding between a Integrated amp or a AV amp with Quad speakers. Did you do a comparison between the 2?
    Milpai
  21. Druida
    Druida
    Sorry, I´m waiting for my quad, and I didn´t ear together, but I hope they will sound very well.
    I will post it when they arrive :hiya:
  22. milpai
    milpai
    Mar 30, 2005
    23
    Hi Druida,
    I finally got my Quad 21Ls and man..they r simply gorgeous - looks and sound. Amazing speakers. Very fast and transparent. Unfortunately listening to old cassettes is a bit of a problem - because they show up the tape hiss.
    I have read i other forums that some one had a lean sound with these speakers and NAD. I believe that person must have got the polarity wrong while connecting the cables. I loved the Audio Physic Yaras too..but cannot justify the extra $700 when comparing to these speakers.
    Quad 21Ls are simply phenomenal value for money :thumbsup:
    Milind
