Qu Re: Component/RGB on PW5
Discussion in 'Plasma TVs Forum' started by IanThornton, Oct 9, 2004.
  1. IanThornton
    IanThornton
    Hi all,
    I've noticed I can switch the component input on my PW5 to be "component" (YUV) or "rgb"
    Does this mean I can connect my Sky+ box direct to the component-in on my plasma with a SCART->3xRCA cable (and obviously switch the component-in more to be "rgb") or are the sync signals not compatible?
    Thanks in advance,
    Ian.
