Qs about Raydon's Foxsat HDR firmware
Discussion in 'Digital TV & Video Players & Recorders' started by t78, Feb 20, 2014.
Tags:
  1. t78
    t78
    Aug 27, 2009
    30
    hi all,
    I've been trying to read up but I've not found conclusive answers to my situation.
    currently running the setup as attached.
    I use the RPi to stream videos from the media server. am wondering whether applying the f/w update to the Foxsat would allow me to use that to stream instead of the RPi?
    also I have read that after the f/w update I can watch saved programmes from the Foxsat on a tablet using MX Player or similar?
    finally - will applying the f/w update wipe our currently saved programmes?
    thanks for any advice :)
  2. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,544
    Redditch
    +4,187
    Applying the firmware won't affect your existing recordings.
    Yes you can watch content on an Android tablet (including newly recorded HD if you also install Nowsters patch).
    Note The Foxsat can't be used as a DLNA client. It can be made to stream from a NAS provided the Humax support files are also present.
  3. t78
    t78
    Aug 27, 2009
    30
    cool. many thanks for the info.
    is it easy to point the Foxsat to a network location and stream from there? (assuming I've added the support files)
  4. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,544
    Redditch
    +4,187
    It needs to be a NAS drive and use the appropriate package. This works by fooling the box into thinking the NAS is a locally attached usb device.
    You should really be posting in the custom firmware thread here, which will also answer most questions by reading the thread
    Media & File Server Bundle for the Foxsat HDR - Release 4 - PART 5 | AVForums
  5. t78
    t78
    Aug 27, 2009
    30
    okey dokes, will look in there.
    thanks for the help :)
