QNAP TS-251+ Repair UK?
martimu
My NAS failed after a firmware update last year and nothing I'm trying is booting up. I've tried all sorts of things that QNAP suggested to no avail and I've had a friend look at it who understands the operation far more than I do (which isn't difficult as I don't get it at all). I only ever used the thing as a back up for my Blu-rays and to stream them and flacs to my hifi.
I'm past caring about the data so I decided to have another go and do a factory reset, as the qfinder refuses to see the hard drives and won't initialise.
Insert paperclip and await beep
Nothing, so I can't even do that.
I'm suspecting hardware issues but don't really know. Any recommendations for someone in the UK who I can send to mend as it's a really rather expensive paperweight at the moment. It's out of warranty so I'm getting nothing more helpful from QNAP themselves.
Just need someone who can test and replace any defective parts and get me up and running again. I had it in a raid config so if the data is still there then great but not the end of the world if not.
Martin
martimu
Have you tried any Youtube vids?
One example -
Thanks, I'll have a look.
To be honest a lot of this goes over my head. I've tried using putty, ubuntu etc but I'm possibly making it worse rather than better!
martimu
Sloppy Bob
I don't just mean that one youtube vids, there are plenty of others. I was just hoping one would contain some kind of solution for you.
Other than that I can't really be of any help. I had an issue with a Synology NAS and a youtube vid helped me.
martimu
Thanks I've looked everywhere and double checked YouTube when you mentioned it but can't spot a solution. Something is not happy and it's way beyond my ability. If I could get the thing to recognise the drives I think I could at least reboot it
bubblegum57
NAS compares might be a place to look at, they sell nas, but I found this
they might be able to suggest a repairer.
brunation
Some QNAPs have serial console ports [1][2]. If you don't get a a comercial repair, maybe a repair cafe could help?
This method is used to recover the content from a TS-251 later in the thread.
martimu
Thank you'll I've have a read of that thread and see if I can work it out. But most of it wooshes some distance above my head :confused::rotfl:
martimu
Have you tried replacing the RAM which I have found can be a cause of failure?
Thank you
No I've not - is there a way of telling if this might be the issue?
Similar threads
Podcast: New Denon AV Products, HDMI 2.1, 8K, DTS:X Pro Sound Q&A with Denon Product Specialists
