BlackBeltBlakey
Hello all,
This weekend I got around to setting up my new QNAP TS-210. I've stuck 2 x 2TB disks inside, under RAID1 (don't want to lose all those important pictures and home movies) and transfered all my existing media onto it. I have loads of music (all mp3s), pictures (nearly all JPG) and a few videos (mostly MKV and MPG files).
When it comes to streaming this media to my PS3 over my WiFi network there are issues. Pictures work perfectly. Music streams perfectly. My MPGs - which are all short home movie snippets of no more than a couple minutes each - all work perfectly. But my MKV files, which are massive in comparison (a few GB each) do not play.
The PS3 finds the files fine but when I select them they just sit there blankly. Sometimes it throws a media error. Once I even got the opening frame of the video up on the TV and then it hung.
I *think* what is happening is that the QNAP TS-210 is trying to convert the MKV file on the fly as it's playing it and - as the processor isn't really designed to do this with this scale of file - it is hanging/failing.
So, my questions are:
1. Is anyone else doing something similar?
2. If so how did you solve the problem?
3. If I want to convert my MKV files what media should I be converting them to?
4. Any good software choices for doing the media conversion?
Many thanks all
Blakey
Many thanks all
Blakey
