Qnap 209 - Questions
Discussion in 'Music Streamers' started by DenzilTK421, Feb 4, 2009.
  1. DenzilTK421
    DenzilTK421
    Nov 6, 2005
    838
    +38
    I originally posted here - but not found any joy...
    http://www.avforums.com/forums/ps3-media-streaming/926588-few-questions-about-qnap-209-a.html
    I was wondering if any perusers of this section maybe able to help...
    Dear All
    I am think of getting a Qnap 209 NAS.
    Primarily it will be used to serve songs and videos to the PS3 & MacBook.
    The questions I have are;
    1) Will I be able to backup the MacBook directly to the 209?
    2) Will I be able to backup the PS3 directly to the 209?
    3) Will I be able to move my PlayTV recordings (and any other file for that matter) from the PS3's menu system to the 209 & will these remain playable from there (or will they have to be moved back)?
    4) Will the MacBook treat any file on the 209 like it would if using a USB attached HDD (will it read write directly, or is it more like a ftp type set up)?
    5) Will iTunes server allow me to sync music videos etc to my iPhone?
    I can't think of any more questions, but please give me an outline of your experiences with a similar setup.
    Thanks in advance.
    Denny
  2. chewystuey
    chewystuey
    Jan 4, 2008
    74
    +7
    Yes - you can play around with Time Machine to do this - but it needs a bit of work.
    maybe.
    i believe you need a usb connection to the PS3 in order to do a backup - ie i don't think you can do a network backup - but you *may* be able to connect the PS3 and QNAP via USB - but i've not tried this.
    You should be able to move some files to the QNAP, but i have no idea with PlayTV - except to say that I believe these are only viewable on the PS3.
    enable the apple sharing server on the QNAP (can't remember what it's called) and my QNAP NAS just appears as a shared drive, so it looks just like any other drive to the macbook.
    the iTunes server on the QNAP is actually just a front end to a DAAP protocol server, so all that does is show the NAS up as a "shared library" in iTunes.
    You can store your music and your library on the QNAP, but this is different to the "itunes server" functionality.
    FYI I have a PS3, Alu Macbook, QNAP 209 II pro and iphone :)
  3. DenzilTK421
    DenzilTK421
    Nov 6, 2005
    838
    +38
    In response to your answers..
    1) I'll have a look about on the net for this, but is this something you ahve tried?
    2) Not a problem about that - I will end up with a spare HDD which I can place in an enclosure and use as a USB backup drive.
    3) Having looked a little deeper into this - it shouldn't rally be a probelm provided the file can be copied to the NAS - I understand that the PS3 would be the only device to read the file.
    4) Would this be like the Netatalk for the iPhone - it shows the iPhone as a shared folder and is browserable as you described.
    5) Still a litlle confused about this. currently i have an iTunes library on an external HDD which is used by multiple users. I would like to still have multiple users access the library (via iTunes server) and have the PS3 be able to access the songs too - does the PS3 access the songs via the iTunes server?
    At the end of it all I want to still be able to update my iphone with music from the NAS.
