Qed TTV Cable
Discussion in 'Cables & Switches' started by kocl, Aug 6, 2004.
  1. kocl
    kocl
    Jan 8, 2003
    589
    PORTUGAL
    +13
    i'm moving from a tv to a plasma, now i'm using a average cable to connect to tv socket, it's worth investing in qed cable?
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    can help, better idea is to get you aerial sorted and use CT125 from antenna to set.
  3. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,068
    The Borders
    +2,528
    kocl
    It sounds mad to install a short piece of 'known' quality cable onto who knows which piece of wet string your builder has used to connect your aerial to your wall socket but I have had a few customers request the TTV cable's and so far they have all said it worked!
    As horny says possibly a better option is to install a decent cable all the way from the aerial to the wall socket first.
    Best regards
    Joe
