QED Sqart
Discussion in 'Blu-ray & DVD Players & Recorders' started by thudspud, Mar 31, 2002.
  1. thudspud
    thudspud
    Mar 28, 2002
    2,399
    Sheffield
    +130
    Hello
    I am about to upgrade my DVD player from a PS2 :eek: to a Sony DVP-NS900B :)
    I am also of thinking getting a QED Sqart to go with it as my brother has one and they seem to perform brilliantly.
    I was just wondering if anybody knew if there was a 'significant' difference between the AV21xx (Fully Wired) and the AV41xx (Wired for RGB only) as I don't need any of the audio connections as they will be handled separately via Digital Coax but if there is no difference I might aswell get the AV21xx series to future proof myself.
    Did that make sense?
    Chris
  2. bob007
    bob007
    The QED AV21 is fully wired, carries audio, S-Video and RGB etc.
    The QED AV41 is just video (RGB) doesn't carry audio.
    I went for the AV41 slightly better picture than the AV21 i was using, still had a tiny bit of noise on bright colours with the AV21, but when i connected the AV41 all noise was gone, it cleaned the picture right up.
    cheers bob
  3. bishman
    bishman
    Mar 29, 2001
    4,904
    83
    hertford
    +174
    I got an AV41 and find it an improvement over my old cable, can't remember the make though.
