QED Silver Annivesary XT
titanax
I am currently using the Dali Viper & I'm not sure if the QEDs will make a major difference, I'm also looking at The Chord Company Carnival Classic. Unfortunately I cant get 2 brands under 1 shop to compare the quality. Can someone with prior advise please?
Also side-tracking a bit do I need to bi-amp or bi-wire my center speaker coz my Mission center comes with 4 connectors.
Oli
Established Member
I am currently using the Dali Red Wave & I'm not sure if the QEDs will make a major difference, I'm also looking at The Chord Company Carnival Classic. Unfortunately I cant get 2 brands under 1 shop to compare the quality. Can someone with prior advise please?
Don't bother - save your money, you don't need to spend that kind of money on speaker cable.
titanax
haha...wasn't really expecting this reply tho! you reckon it wont make any difference?
D
Deleted member 30535
There are a number of reports that the Silver Anniversary can be a tad on the "bright" side.
If you're looking for a brand name but good value, look at the Van Damme Blue series 2.5 sq mm. It can be bought in the Power Buy section for about £1.90 per m, or if you're up for buying a quantity, you can get 100m for a few pence under £130.
R
recruit
I'll second that - best advice you'll get.
Both comments are not the best advice :nono:
If you have a dealership that is willing to loan you the cables to try out then I would urge you to do that.
sweeping statements like the above do not merit good advice, cables can make a difference but depending on partnering equipment/setup.
R
recruit
The above is sound advice.
Oli
Established Member
Until i see some real reviews of cables that prove they make a difference, I think it's a fair statement to make.
The whole loaning equipment to try stuff out is all well and good but unless you properly blind test everything you try (which i expect accounts for 0.0001% of hi-fi consumers) you are just going to convince yourself into spending money needlessly.
Anyway, this has been said countless of times in another thread.
titanax
you guys crack me up :D:D...but its sound advise... now I need to search who sells Van Damme Blue in Singapore.
As for my other question on bi-amping my center speaker - does it make a big difference? I mean why else would it come with 4 connectors??
evans
Established Member
I just put belkin pureav silver series speaker wire 16 gwg on my B&W speakers very good wire crystal copper . can recommend, 10 pounds sterling + shipping for 9.1 M from a internet Uk site.
titanax
I could not get the van damme retailer in singapore & the cost of getting it shipped from the UK is really expensive...so I got myself the Supra Ply 3.4/S. I must say they meet my expections :D
Amazon Fire TV Cube Gen 3 Review: Coming Soon
