QED Silver Anniversary???
Discussion in 'Cables & Switches' started by AVnoob, Oct 14, 2005.
  1. AVnoob
    AVnoob
    I'm very new to playing around with Home Cinema and have part bought, part inherited the below kit for my build (I know most of it is probably very old but in it's day it was good gear (wasn't it?)
    ADVICE PLEASE!!! The burning question is...
    To connect this lot up do I need to shell out on something like QED SIlver Anniversary, I've found a guy on eBay selling it for £3.60 a metre (if I buy 25 metres) which is cheap for half decent speaker cable but....based on the below kit list do I really need it to get the best out the kit or will a '£1 per metre' job do the trick for me? I've seen some cable on eBay, £1 per metre (http://cgi.ebay.co.uk/GREAT-SOUNDIN...Qcmd ZViewItem)
    ...will this really be up to it? Or do I go for the Silver Anniversary? I've already bought an IXOS Subwoofer cable but that's all the cable I have bought (so far!!!)
    One more question - banana plugs.....do I need them? Pro's and Cons? QED Airloc or cheapos?
    Thanks everyone! I'd really appreciate the benefit of your knowledge!
    Here's what I've got:
    Yamaha YST-SW80 Subwoofer
    KEF Coda front speakers
    AE centre speaker
    Boston Acoustics VRS Micro rear speakers
    Sony STR-DB930 amp
  2. AVnoob
    AVnoob
    sorry!
    forgot I had posted this already.....moderator please delete
    really soz! :)
