qed q sync set up problems on panyw5
Discussion in 'Plasma TVs' started by spinner, Oct 10, 2004.
  1. spinner
    spinner
    Aug 8, 2004
    182
    newcastle
    +5
    just got a qed q sync box for the scart to vga thing.....now seem to be having real probs setting the thing up,basically the w5 just doesnt want to know,now on PC mode and only a blur of a picture every 5 seconds or so,have you got to manually adjust the sync? if so how? plasma is uk model and output in dvd is set to RGB...thought this was a simple hook up....what am i doing wrong?
    cheers in advance for any help..
    andrew
  2. symanski
    symanski
    Jun 20, 2002
    874
    Scotland
    +8
    Haven't heard of similar with my RGB to Plasma VGA unit. Are you sure it's working ok?
    All the best,
    Dr John Sim.
  3. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    Sales pitch there from the guy who makes the best ones, the QED basically is fussy about the RGB signal. What device are you connecting with it? Make, model, then we can say if it can be made to work.
