QED Q-Sync Active Sync Extractor SCART Vs JS RGB to Plasma VGA Version 2
Discussion in 'Cables & Switches' started by sprout, Jul 14, 2004.
  1. sprout
    sprout
    Dec 15, 2002
    6,369
    Bridwater Somerset M5 Junction 23/24
    +251
    Hi all
    Has anyone here had the chance to try the QED Q-Sync Active Sync Extractor SCART and been able to compare it to J S Tech's RGB to Plasma VGA Version 2?
    If so would be interested to know.
    Also if anyone believes there is an better alternative?
    I will be using to interface with a Sony pfm-42b1e.
    Thanks in advance for any help.
    Martin
