QED Original Cable
Discussion in 'Cables & Switches' started by a12yon, Mar 23, 2005.
  1. a12yon
    a12yon
    Mar 14, 2005
    22
    Falkirk
    I need 20-25 meters of QED Original Cable and have just narrowly lost out on an e-bay auction. Does anyone know where the best place is to buy it??
    Its £2.75+ a meter everywhere I have looked so far!!
  2. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    I wouldn't worry about it too much. I've got some of this and it's bog standard zip wire in a nice white sheathing.
    You can normally get about 50m of speaker cable for about £12, just have a look over the Maplins site or the CPC site. :)
  3. a12yon
    a12yon
    Mar 14, 2005
    22
    Falkirk
    Seems that some people are of the same opinion as yourself, however I have been told that as I am going to the bother of putting the wires into a wall cavity and under the floor it is worth spending a bit extra for cable. Ive purchased Silver Aniversary Cable for my front 3 speakers and only need cable for the rear sattelites, Ive found a site I can get 25 meters of QED Original for £49 delivered,however I will check out your info first!! Cheers
