QED One series - fully wired scart to scart
Tuxedo
Hi All,
I've seen this cable as a 2 pack in Costco and wonder if anyone had any views or comments on its quality as I have not been able to find it on the web.
many thanks. :hiya:
RAINS
Tuxedo,
I'm not sure about a series 1 but generally QED are very good scart leads.
I have the flat type fully wired from my cable to LCD and a picture only from my DVD to LCD.
As you know component are the best signal apart from HDMI which is still being contested but if you need to use scart then i would recommend.
My leads were about £25 each of ebay.:smashin:
Tuxedo
Hi Rains,
Thx for reply. They're £24 for a pair which sounds like very good value only I was not sure if they were the same as the ones you could get on the high st. i guess because they were only £12 each, I suspected they might be inferior spec or soemthing.
Cheers.
