QED Musiq setup advice
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by joni30, Mar 12, 2013.
  1. joni30
    joni30
    Mar 12, 2013
    2
    Hi All,
    I would like some advice on setting up some QED musiq amplifiers I have recently acquired second hand.
    I am planning on creating a budget multi room system using these as the amplification system.
    I don't have any QED controllers, I want to use the musiq's just as dumb amplifiers which will be fed by a logitech squeezebox or similar.
    However when plugging the amps in for test I can't get any sound out.
    I am plugging some known tested speakers into the output on zone 1, and running a known good source into line in 1. Can see red light on front illuminating, but no sound. Jumper settings are all set to 'off'. Gain is set to max.
    Any advice much appreciated, not sure if I am missing something (ie do the amps need a controller to be plugged in to work) or are they just faulty- they were second hand off ebay.
    Cheers, Jon
  2. joni30
    joni30
    Mar 12, 2013
    2
    no one with any experience these amps out there?
