QED Micro 2 QED Silver
Discussion in 'Cables & Switches' started by dinoprada2003, Aug 20, 2004.
  1. dinoprada2003
    dinoprada2003
    Jul 7, 2004
    4,019
    2
    LONDON
    +6,730
    My speakers are connected to my amp via QED micro.Now I want to upgrade my speaker cable to improve sound.I was thinking of QED Silver Aniversary as a good step up.However!,im on a tight budget and can only upgrade left right and centre now and the rears in the next couple of months.Before I go out and buy a load of cable I have a question that people on here might be able to help with an answer? :D
    1.)If for the time being I connect Centre,Left,Right with QED silver(aniversary)
    and rears with QED(micro) Till I can afford to complete whole setup with QED silver,will this result in poor sound I.E worse than if it all was just QED micro?
    2.)If above answer is no well with only left,centre,right connected with better cable will it then improve sound for those channels?
    Thank's for all the newbie help :thumbsup:
    DINO.
  2. Duster
    Duster
    Dec 4, 2002
    421
    UK
    Yes :smashin:
    QED Silver Anniversary is a much better cable.
    I did the same as you, for my rear channels, going from QED Micro to QED Silver Anniversary , and it does sound much better.
    The only thing I will say is, if your AMP is lower end, you may not hear that much improvement.
  3. dinoprada2003
    dinoprada2003
    Jul 7, 2004
    4,019
    2
    LONDON
    +6,730
    Thank's Duster! sadly my amp is low-end crap sony strde495 still waiting for the cash to upgrade to a Denon AVR2803 hence why im hoping to change system cable to QED Silver :D
