J
jackal
I use three QED Qonduit Mains conditioners on my system (six, four and two sockets).
I have noticed that they are all internally fused with a 10 amp fuse and the qonduit cables are the same.
The power amp rating on the 2 socket MDH2 is 2KW. SO here is the question.
My new power amp draws at maximum power 2.5KW, but is internally fused at 15amps.
Should I not try to run it off the MDH2, or do you think I would be OK to do so.
I would have put this in the cabling section, but it would have inevitably drawn in all of the 'snakeoil' gang.
