qed hdmi-p vs ukhdmi maestro
Discussion in 'Cables & Switches' started by jwyg, Jan 30, 2009.
  1. jwyg
    jwyg
    Jan 16, 2009
    373
    +8
    i can get the qed hdmi-p for £25 (1m) vs the ukhdmi maestro at £19
    is the 6 quid going to make any difference at all or should i save it (i need two cables)
  2. y2k
    y2k
    Jan 3, 2008
    3,300
    Banana Republic
    +291
    Have a look at the "HDMI The Facts" sticky at the top of this forum, you don't need to spend that much money on a 1m HDMI lead.
  3. Member 319784
    Member 319784
    Nov 3, 2008
    1,502
    Malvern
    +240
    Save it. Go for the meastro. It won't make any difference in picture quality.
  4. Import racer
    Import racer
    Sep 5, 2007
    954
    28
    +81
    I have tried both the QED qunex and UKHDMI express back to back and couldn't tell any difference and the express cost me only £7 delivered.
    Good cables, i now have 5 of them in different lengths and will propably buy more.
    :smashin:
  5. jwyg
    jwyg
    Jan 16, 2009
    373
    +8
    cheers - i did have a look as i'd seen other recommend ukhdmi before - it's just that the qed was quite a keen price compared to normal rrp.
    does that arguement then extend to not needing the maestro? i could get the akuna cable, the next step down, for £8.50 for 1m...!
  6. Member 213491
    Member 213491
    Aug 30, 2007
    860
    43
    Oxford
    +101
    Hello jwyg,
    Its all upto you.
    :clap:
