QA 3020i wall mounted?
JoeSla
Does anyone have Q Acoustics 3020i speakers wall mounted? Using the official QA mounts?
They are quite deep (28cm) - do they look funny sticking out of the wall so far?
This will be in a 6x5m kitchen/diner/living space, with speakers on the wall above some bench seating which is opposite end of room to the kitchen units.
Many thanks!
Onlythesound
Do you mean these?
I haven’t any experience of them but once considered them for my Concept20s. In my opinion, using these immediately chucks any opportunity to finely adjust your sound, in the bin. They’re going to put your bass port on the 3020 right against the wall unless you can be extremely inventive…..and limit your options with toe-in etc.
personally I’d try to put them on a good pair of stand from someone like Atacama. Hope that helps a bit.
