QA 2020 plus Klipsch S-10 comination?
nadg63
In my TV room I have a QA 5.1 system, 4x 2020, 2000C, 2070S and as the Sony STR-DH790 Rx will run 7.2 I'm considering running some high fronts using some spare Klipsch S-10 'surround speakers - would this be a compatible combination? (knowing front heights do not really do much) Not wanting to run ceiling mounted Atmos speakers in there, I already have them in the projector room for movies.
Gasp3621
Those S-10 look like bipole speakers so they offer more dispersed soundfield. They would be ideal as surround sides and then you could move your 2020 pair which are there now to either behind the listener as surround backs (7.1) or move the 2020 as front heights (5.1.2) similar as below. I wouldn`t use the Klipsches as front heights (if you meant that) cause they aren`t direct radiating.
dsc_0097_small-jpg.779131
dsc_0100_small-jpg.779133
dsc_0098_small-jpg.779132
nadg63
Thanks, yes the S-10 Klipsch are their bipole type. Was going to use them as front heights but maybe I’ll just hang off and shop around for a pair of 2010’s or QA 7000 satellites instead, (possibly a pair of Klipsch Quintet satellites even as readily available!?)
Podcast: The Best TVs of 2021, plus our favourite & memorable reviews of the year
