None of which will probably work, I believe, the message is confusing as it appears to relate more to the smarthub. Samsung do suggest some setting changes to the network settings in the tv but this tends not to work either. Post #3229Also hoping for a fix for this, I'm using ethernet connection to a Q85 and keep getting the pointless 'network connected' pop-up in the middle of movies, double annoying as the notification has to be manually cleared.
Just had a thought, wonder would extending the IP/DHCP lease time in the router settings stop it from appearing so often? Might try this.
