NeonLight13
Hi folks
I've been having some issues and hoping that one of you immensely knowledgeable lot can maybe help me out by suggesting a solution?
I'll try to outline the problem as best I can. I have an RTX 3070 GPU, and my PC is hooked up to my TV. I wanted a TV that supported 4k @ 120Hz over HDMI 2.1, and so I went for the Samsung Q70T (55") as it claimed to support this.
However, I'm having all sorts of issues with it, including the following:
* Handshaking failing completely unless the PC is turned on first and left for a minute before switching on the TV (and even this isn't 100% a solution)
* Frequent flickering, when a resolution 'takes' on the TV at all. Sometimes it will, without warning, just cease to support the input and become a compressed band of colour and glitches taking up the top third of the screen.
* Signal loss - for instance, I will be playing a PC game and the signal will completely drop, but comes back if I switch into/out of game mode (it doesn't matter which, incidentally - the issues occur whether I'm in game mode or not), or if I unplug and re-insert the HDMI cable.
* Resetting of status - removing Input Signal Plus designation and pushing the resolution back to 1080p as a result.
I have tried two different HDMI 2.1 cables which claimed to be certified - a Club 3D and a Monoprice. The TV is on the latest firmware, too.
I don't think the problem isn't related to the graphics card specifically because I have tested on a friend's monitor and it works fine. It also worked fine on my old TV at 4k 60Hz, so I don't believe the card to be faulty. It doesn't seem to make any real difference whether I'm in RGB/4:2:0/4:4:4 colour mode either (or with G-SYNC on/off in the Nvidia Control Panel - although that option only appears when in Game Mode anyway).
Unfortunately, the delay in arrival of the second HDMI 2.1 cable (due to Brexit customs delays) meant I was outside of the 28 day "refund for any reason" window with Samsung. But their support people now are refusing to entertain the prospect of a refund because of being out of that window.
I also spoke to Samsung's live chat product support, which gave me this (I'm presuming/hoping (!) entirely wrong?) response:
So, seeing as my prospects of actually getting my money back appear to be slim-to-none, does anyone have any idea of how I can get the PC and the TV to play nice together?
