Q4 2007 LCD HDTV upscaling and V+ Upscaling Question
Discussion in 'Cable TV & Virgin Media TV' started by Solid79, Sep 5, 2007.
  1. Solid79
    Solid79
    May 3, 2007
    29
    I currently only have the XL standard TV package but am looking to buy a 40" LCD HDTV this Autumn (Either the Sony X3000, Samsung F86 or Toshiba Z3030)
    Question is will the picture quality benefit from a V+ Set Top Box or will the TV's built in upscalign processes (eg Sony's Bravia EX) be all i need?
    Basically is there any benefit whatsoever of getting a V+ Box for SD feeds to a new HDTV LCD?
    Many thanks in advance
    Solid
  2. Parmenion62
    Parmenion62
    Sep 19, 2005
    623
    2
    46
    Bristol
    +102
    There is a huge benefit from V+ upscaling on my TV - the picture is much better through HDMI than through RGB scart. I have a 32" screen so I would think with your bigger screen you would notice the difference. It depends on whether the newer TVs have better scalers in them and I suppose the resolution of your LCD screen i.e is it 1080p?
  3. meltonboy
    meltonboy
    May 31, 2005
    3,145
    London
    +586
    Hi mate
    I have a 2 year old panny plasma (see below) and there was certainly a difference in SD picture quality when i went for the TVD outputting 720p, especially on newer stuff.
    MB
  4. ajnicho
    ajnicho
    May 27, 2006
    165
    Liverpool
    +6
    Yes. I'd have to agree.
    The picture on my 42" Plasma is stunning when connected via HDMI. In comparison, when connected through SCART it was almost unbearable.
  5. Solid79
    Solid79
    May 3, 2007
    29
    OK Thanks for the heads up.
    So which consumer set top box is widely accepted as the best for VIrgin Media Cable SD services? Is their V+ Box pretty much the only option? Can you get the V+ service without using their own box, and if so which is the reccomended box for SD upscaling via HDMI?
  6. maximum
    maximum
    Jun 25, 2007
    48
    You can only use Virgin Media boxes to receive their service. I recently tested it with the new Sammy 40F86 and performance is miles better through HDMI than Scart.
