Q150e overheating my amp
Discussion in 'Home Cinema Speakers' started by djc101, Aug 10, 2002.
  1. djc101
    djc101
    When i connect my REL q150e to my amp using the supplied high level input cable it overheats my amp and i think it might have fried my new avca11sr (see thread in amp section). Trying it on an old amp it runs fine connected through the low level input but connect the high level one and it heats up in a matter of minutes!
    Anyone had similar problems or got any ideas?
    What kind of load does the sub give the amp when its connected like this?
    Dan
  2. russraff
    russraff
    Aug 1, 2000
    2,458
    Newcastle
    +80
    That doesn't sound good :(
    For all intents and purposes the REL should be nearly transparent to the amp using the High Level cable (someone tell me if I'm wrong?). On my REL Storm III there are 3 connections that the High Level cable can be plugged into; is yours in the correct socket, or is there only the one?
    Older Q150's had earthing problems that resulted in a loudish humming (newer Q150's had a switch on the back to solve this problem). Perhaps this is a more serious manifestation of this, though I can't see how.
    Other than that I would take the sub back to the dealer, along with your old Denon amp, and see if a different sub makes the amp hot. If it doesn't then your original sub is at fault somehow.
    Russell
  3. Member 14718
    Member 14718
    Aug 10, 2002
    376
    Essex
    +25
    The high level in on the q150e should be about 100K Ohms and invisible to the amplifier, double check the lead is wired in correct. You could also check that there are no short circuits or low impedance between black and red, and black and yellow whilst the speakon is still plugged into the unit and the q150e switched off.
    If the lead reads ok then you may have to open up the speakon plug to check that the red and the yellow go to +1 and +2 and that the black goes to either -1 or -2. If the plug is wired ok then maybe REL have encountered the problem before, it's worth asking them i'm sure they would be pleased to help.
    Anyway good luck
  4. djc101
    djc101
    Thanks for your thoughts guys.
  5. magking
    magking
    Jan 6, 2001
    380
    Norway
    Just thought i should mention that i have a REL Q400 connected to my Denon AVC A11SR with both low level and high level with no problems.
    It is probably the cable or sub that cases a short cirkut.
    Good luck.
