Q re Sky+ and DVD Recorder connection
Discussion in 'Blu-ray & DVD Players & Recorders' started by Messiah, May 7, 2003.
  1. Messiah
    Messiah
    Apr 22, 2002
    7,616
    +338
    Can anyone please tell me if I can use the TV RGB SCART output on my Sky+ to connect to RGB SCART input an a DVD Recorder (such as E50) to get higher quality recordings.
    I currently use the S-Video output to my amp so the SCART is free. Also, if not, does the AUX/VCR SCART output deliver RGB?
    Thanks.
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,722
    Warwick
    +2,600
    Yes you can - this is what most people do in fact.
    The VCR Scart only outputs composite (as it's only DVDRs that can take RGB input). Therefore if you want to record in RGB then you must use the TV Scart.
  3. Messiah
    Messiah
    Apr 22, 2002
    7,616
    +338
    Excellent, thanks.
