(Q) Longer One Connect cable for QE75QN900A Neo QLED 8K (2021)
espilva
I bought the QN900A shorly after it was available hoping it'd come with a 5m One Connect cable, which wasn't the case.
Months after getting the TV, and months after a cable of such length was announced at Samsung's web (VG-SOCA05), the cable is not available. Furthermore, Samsung's customer service, tech support and the like don't know when --or if-- it'll be available, let alone its price. So, I was wondering if anyone having a similar problem with the 2021 8K range has tried using a previous generation cable from 2020. Or if there's a third party solution, since Samsung itself can't provide any answer about the availability of their cable.
Thanks so much in advance!
Anostraca
Hello,
Search for the cable by its code: VG-SOCA05/XC
You might find some results in your local stores (I did, its pretty expensive but it is here)
Podcast: Anthem AVM 70 Review, EQing Your Home Cinema Sound System and More...
