Q Link
F
Focker
I have connected my Panasonic TH37PV500 Plasma to a Pioneer DVR-930H-S DVD recorder with a HDMI cable for playback and a fully wired scart for the Q LINK features,and recording from the inbuilt freeview tuner.
From what i understand, apologies for anything that sounds stupid its all new to me, i should be able to program my recordings from my plasma-using either the timer program menu or the direct tv record. Apparently the plasma should also turn on and to the correct AV input when i press play - this also does not happen. Even when the plasma is on i have to select the correct AV input manually.
Can anyone help me in getting my system up and running.
Regards
Focker
F
Focker
According to my manuals they say Q Link compatible devices.
Trending threads
