Q Acoustics Q7000.1 Review
saru360
Hi how do you comprare this Q7000.1 with the mass pack, but only speakers, since i already have other sub.
Best Regards
3OXA
How do these compare to MA Apex range? Or even the Mass speakers?
nenito2k
would love to know Q7000i vs MASS ! obviously the ratings speak for themselves 9 vs 7 !
But is the difference worth selling my mass and get these ?
ruffian2205
Anybody have the stands for these. I have two of the stands but haven't used them in a while - now I can't figure out how to fix them now I want to used them again! Anyone have a scan f the instructions?
prabbhopal
Hi, I have a copy of the pdf I can send you. I've tried attaching here but have been unable to. Want to give me your email address so I can send it?
ruffian2205
Thank the QAcoustic support people sent me it. Unfortunately the plastic at the top of speaker stand doesn’t seem to hold the speaker no matter what I do.
Sloppy Bob
There should be an allen bolt to hold it in place. The plastic on its own is just a piece of trim.
IIRC it's the same bolt, but longer, that is used for the normal stands to attach them to the base.
ruffian2205
The bit where the bolt attaches the plastic at the top of the stand appears to have cracked so it won’t tighten any more. The one at the front which holds the speaker unit in place just turns and turns and doesn’t tighten. Thanks for your help though. I’ve decided to just site the left surround on my desk instead.
nenito2k
too bad this topic is not as rich as other "speaker topics" seems the Q7000i do not interest forum member.
@Ed Selley or @Phil Hinton or @dante01
Do the Qacoustic speakers match tone nicely with yamaha aventage receivers ? my guess would be yess, as the avr is considered "NEUTRAL".
also is there any member @Sloppy Bob or @ruffian2205 that compared these with the MASS speakers. I plan on selling my MA and get these....in 6 months or so
Sloppy Bob
I did compare them with the First Gen MASS speakers, not the ones you can buy now which are far smaller.
I thought the Q7000i was more musical and just had a bigger sound. There are reviews on the site for them if you hadn't seen them.
The newer MASS speakers don't seem to be as well-received as the First Gen from reading around on here and a few other foums. Again, they're considerably smaller and that's obviously going to make a difference.
However, I'm not sure if I'd sell my First Gen MASS to get these. It's not a massive upgrade.
If I was looking to upgrade it would be to larger speakers such as MA Bronze or QAcoustics Q3000 series.
dante01
Yamaha AV receivers ordinarilly have a reputation for having an audio signature that is biased towrds the upper frequencies, not bright, but not warm or neutral either.
You shouldn't have any issues partnering any of Q Acoustics speakers with any of Yamaha's receivers. QA speakers tend to be relatively neutral. They'd be a bit warmer to listen to than the Monotor Audio Mass speakers and Monitor Audio speakers tend to be more clinical.
The speakers tend to be the element that determines the overall sound of a setup more than the device powering them. The audio signature of the speakers should ideally be in tune with your own listening likes and preferences.
nenito2k
@Sloppy Bob
I knew of the reviews..that is why I asked those questions:)
Am very aware the upgrade is not that big. But in this case a little better is fine by me...as I don't have space..
And yes I wanted an answer compared to mass gen 1 speakers. That are better than gen2 obviously...
@dante01 thanks for the input like usual
nenito2k
If you want a more noticeable upgrade I'd switch your AVR and add some Atmos channels.
that is also part of the next upgrade :)
on a side note @dante01 and @Sloppy Bob
recently i tested 2 tracks from "nier automata OST"
1) 192kbps MP3
2) LOSSLESS 48/24-bit FLAC
i cound not hear a difference....i tested for about 10mn going back and forth....so
is that "normal" ? or is it simply because my gear sucks ? 450$ AVR (at the time) and my MASS g1 speakers ?
do i need 1000+ speakers or TOWER ones ?
do i need a 1000 euro AVR ?
Sloppy Bob
For music you're much better off with a stereo amp or spending a fortune on something like an Arcam.
You'd also need a significant speaker upgrade as well.
nenito2k
my music use is 5% (70% movies & 25% games) so stereo amp is not worth it...
so basically with sub 1000 euro speakers or a "normal" AVR hearing no difference between FLAC and MP3 is normal then ?
Sloppy Bob
A cheaper alternative is some of these.
:p
I'm far from a music buff, I'm hard of hearing so don't spend a huge amount of time listening to music anymore and I certainly don't appreciate audiophile equipment so I'll leave than one for others.
nenito2k
I see @Sloppy Bob on any case q7000i will certainly be an upgrade from my mass anyway for music; that is satisfactory enough for me
Cheers!
If anyone else has these speakers please post your review-impressions...theis topic should be useful to other
Sloppy Bob
Honestly.
I think you're over-egging them a bit.
They'll be a little bit better but I wouldn't spend the money on that kind of an upgrade. It would be like going from a 49" TV to a 50" TV. It's a small, incremental difference.
nenito2k
@Sloppy Bob
I agree. Q3010i are better than q7000i that is sure...but there are quite big...and MA apex are too expensive even 10 years after launching...
I still have a few months to think this over
Gasp3621
@Sloppy Bob
I agree. Q3010i are better than q7000i that is sure...but there are quite big...and MA apes are too expensive even 10 years after launching...
There is Apex A40 + 2pairs of A10s and stands on classified. I don´t think you will find anything as good for same money as new. Sure you need better receiver, but most people are not lucky to buy everything right away. Build slowly and you end up with something really good. Receivers come and go as every frickin year there is new model, but good speakers you can keep +10years.
nenito2k
@Sloppy Bob or @Gasp3621 @prabbhopal @Ed Selley
quick question
trustedreviews.com mentions "Small, fiddly cable terminals" does that mean i can't use them with 2.5mm² speaker cables ? somewhat needs 1.5mm² ? :confused:
Podcast: CES 2021 Special - Sony, LG, Panasonic, Samsung, TCL and Hisense TV news and more...
Latest News
NAD Launches CI 16-60 DSP Amplifier
  • By Andy Bassett
  • Published
Sky seals Studiocanal movie deal
  • By Andy Bassett
  • Published
iFi Audio launches iDSD Diablo DAC/Headphone amp
  • By Andy Bassett
  • Published
Samsung launches Galaxy Buds Pro
  • By Andy Bassett
  • Published
Samsung launches Galaxy S21, S21+ and S21 Ultra smart phones
  • By Andy Bassett
  • Published
