Question Q Acoustics M4 soundbar or M2 soundbase?
Discussion in 'Soundbars, Soundplates & Soundbases' started by Velvet, Jul 16, 2018.
  1. Velvet
    Velvet
    Jul 16, 2018
    Sheffield
    In terms of sound which device should i get? It is going to sit on my media unit.
    Both get great reviews which makes it difficult to decide!
  2. Bradley72
    Bradley72
    Aug 28, 2017
    Yorkshire
    I personally have the M4 and I have to say it is absolutely fantastic. I listened to both the M4 and the soundbase in Richer Sounds and much preferred the M4. The only slight negative (if there is one) is that its volume steps are quite large, in that it goes from fairly quiet to a decent volume in one step. Once you get used to it though you will just want to crank it up.
