Q Acoustics M2 Soundbase Review & Comments
Discussion in 'Soundbars, Soundplates & Soundbases' started by Greg Hook, Dec 15, 2017.
    1. Greg Hook
      Greg Hook
      Moderator & Reviewer
      Nov 25, 2001
      23,408
      2
      In a secret location with Jennifer Lawrence
      +10,342
    2. invisiblekid
      invisiblekid
      May 10, 2009
      4,564
      4
      +3,466
      Anyone have a preference with this or the M3 Soundbar?
    3. vetch1
      vetch1
      Jun 21, 2014
      447
      Swansea
      +67
      When comparing to similar (alternative) choices like the Cambridge TV5 (the V2 of which has been out for about a year) it would be nice to have a more in depth comparison. Rather than just (incorrectly) stating that the TV5 doesn't have an HDMI connection.
    4. samgamgee
      samgamgee
      Dec 30, 2008
      637
      +89
      Anyone own this? Gets brilliant reviews at a decent price. Obviously no surround though.
    5. MikeTaylor
      MikeTaylor
      Apr 19, 2017
      68
      11
      London
      +23
      Hey. I have one and generally it does everything it says on the tin. However, I am having real problems with vibration distortion. My LG55B6V sits on top of it and at certain volumes, certain frequencies cause buzzing a distortion. QA have been super helpful in trying to sort it and I've tried cork and felt pads. I've just ordered some AudioSerenity ISO-9H Gel Isolation Pads and we'll see if this nails it.
    6. samgamgee
      samgamgee
      Dec 30, 2008
      637
      +89
      Hey, thanks for answering.
      The reason I’m looking at this is it gets brilliant reviews and I can’t see an equivalent soundbar. My TV is up on the wall so I shouldn’t get issues like you. The problem would be it might look ugly on its own on the unit, unless I can find a unit that it can fit in nicely.
      Do you think it’d be daft buying something like this when I don’t need the TV on top of it?
    7. MikeTaylor
      MikeTaylor
      Apr 19, 2017
      68
      11
      London
      +23
      No - its a very nice bit of kit and when it works, it works well. Just this damn buzzing distortion...
    8. Slates71
      Slates71
      May 18, 2006
      635
      28
      Derby
      +43
      I'm looking to buy this after reading such positive reviews online. One question, I will have to position it on the lower shelf on my TV stand. With it being underneath the TV does the sound come across well while watching TV? Ideally I'd like it under the TV stand
    9. samgamgee
      samgamgee
      Dec 30, 2008
      637
      +89
      A review said not to put it in a cabinet as the disconnect sounds strange. Anyone done this?
    10. xand_xand
      xand_xand
      Feb 22, 2009
      47
      I have been toying between M2 and sky soundbox and have decied on Acoustics M2
      I have Samsung Tv with ARC. SKY Q. PS4. and the M2
      Am i overthinking things but is my best setup simply:
      M2 ~hdmi to~ TV ARC
      SKY Q and PS4 ~hdmi to~ TV HDMI inputs
      Then simply use the Tv as the hub, selecting source on the tv remote.
    11. samgamgee
      samgamgee
      Dec 30, 2008
      637
      +89
      Where is it going? The M2 I mean
    12. xand_xand
      xand_xand
      Feb 22, 2009
      47
      Hi.. physically ...on a low level cabinet..TV is on wall slightly above.
    13. BiloBlue
      BiloBlue
      Aug 3, 2005
      214
      St helens
      +20
      Also struggling - I’ve got an M2 which I’m sitting my LG Oled tv on top. I’ve connected my Sky Q box to the M2 via the Optical Cable, and then connected my M2 to the TV using the HDMI Arc. Sound is great!
      However, once i flick over to my Amazon Fire TV, I have no sound whatsoever. How can I ensure sound on both? And also on my PS4 once connected?
    14. xand_xand
      xand_xand
      Feb 22, 2009
      47
      Can't you just hdmi your PS4 to a spare TV hdmi input.
      Select the source using TV remote...
      The M2 will take care of the sound via arc?
    15. samgamgee
      samgamgee
      Dec 30, 2008
      637
      +89
      How close? About a foot? One review says it sounds strange with the sound coming from below the TV. Do you notice this?
    16. xand_xand
      xand_xand
      Feb 22, 2009
      47
      Why not just hdmi your sky box to TV...
      Then M2 to TV via the hdmi arc. This will take care of your sound.
      You don't need to use optical too ?
    17. stevebrass
      stevebrass
      Apr 12, 2011
      11
      3
      Are there any audio out settings on the Amazon Fire? Try changing these.
    18. gabriel959
      gabriel959
      May 1, 2011
      154
      +9
      Hi Mike,
      Isn't the crescent stand a lot bigger than the soundbase? I have been thinking about getting an M2 but I am worried it will look a bit silly.
    19. MikeTaylor
      MikeTaylor
      Apr 19, 2017
      68
      11
      London
      +23
      The stand on my 55B6 is just the same size as the soundbase. I've stopped the buzzing using some neoprene acoustic button feet i found on amazon. I also realise that having an ikea metal frame on wheels is probably not helping... But the size (width and depth wise) is fine.
    20. gabriel959
      gabriel959
      May 1, 2011
      154
      +9
      Ah! I thought yours had the crescent stand :)
    21. gabriel959
      gabriel959
      May 1, 2011
      154
      +9
      Ok, so got one of these from Amazon (Used - Like New) for £209, which comes with all accessories. I have seen that it comes with an HDMI cable so I can use it with my TV (49SJ810V).
      My setup is going to be pretty simple. The M2 connected to the TV via the HDMI Arc cable. The DVD Player (Cambridge Audio DVD89) connected to the TV via HDMI. Do I also need an optical cable or some other cable to connect the Soundbase to the DVD/CD player?
    22. zeppelino
      zeppelino
      Jan 24, 2018
      1,760
      84
      UK
      +431
      No.
    23. gabriel959
      gabriel959
      May 1, 2011
      154
      +9
      Thanks so if I want to play a CD without switching the TV on that will work?
    24. zeppelino
      zeppelino
      Jan 24, 2018
      1,760
      84
      UK
      +431
      Oh, for this scenario you’d need the tv on - or connect an optical cable and switch sources on base as necessary.
    25. gabriel959
      gabriel959
      May 1, 2011
      154
      +9
      Hi all, I went ahead and bought one of these. I am very pleased with the unit overall, it sounds amazingly well for a device this size and it looks quite nice but I am having some small issues with bluetooth, basically I can pair both my Moto X4 and my wife's iPhone SE without issues but sometimes when I switch the unit on and change the source to bluetooth our phones never connect to the unit, something I have to cycle through the sources to connect them, sometimes I have to disconnect them... does this happen to anybody? Does anybody know how to resolve it?
    26. TreborEdit
      TreborEdit
      Feb 2, 2009
      13
      Ignore - HDMI arc and AVR having the ability to pass through all audio to the display saved me having to use analogue interconnects...
      ____________
      Hello! Can I just double-check - were the analogue inputs tested in this review?
      I’m considering one of these and due to the lack of HDMI inputs I intended to connect to the M2 via RCA from my existing AVRs pre-outs.
      Thanks!
