Q ACOUSTICS 2010i or WHARFEDALE DIAMOND 9.1 Speakers
a1exi
Im split between these two speakers. I'm going to be hooking them up to a NAD 3020i amplifier, as well as my turntable. Could anyone give me any advice? Thanks
Jameskatie
have you had a demo? if not then thats the only way.
If you have and still cant decide or you think they sound same, go with ones that look best :p
PC1975
They're very evenly matched in terms of quality. I had the older 2010 (not i) and the smaller Diamond 9.0 at different times so I couldn't make a direct comparison but was equally impressed by both. Personally I'd go for the Diamond 9.1 or even 10.1 of which Richer Sounds have a few pairs left at £99. I think both of those models look nicer than the 2010i and Wharfedale have years of experience of manufacturing the Diamond series which have recieved excellent reviews.
Thye bottom line is that both the Diamonds and the 2010i are as good as you'll get for the money and I think you'd be happy with either or.
a1exi
Thanks a lot for the reply, I went with the 2010i in the end as they were the only ones they had in stock.
Panasonic HZ2000 OLED TV Review: The best OLED for movie viewing in 2020
