TellyTel
I have just setup my q acoustic 2010i/2000ci and 2070si in a 3.1 system connected to a Denon avrx2000, I noticed after woods that the crossovers were set as 40mhz I think for the centre and 60mhz for the fronts.
Should I change these to all 80mhz as it seems 80mhz is the recommended default setting.
Also after running Audessey I found that my sub was to loud and the centre dialogue was a little to low until I turned volume up to about 60db and it was ok but this also meant the sub would be even louder.
Im going to run Audessey again but turn the subs volume switch down to about 30% and maybe switch the fronts and centre crossover to 80mhz?
I may also try turning dynamic EQ off?
what do you think guys.
thanks
thanks
