salsa-king
Established Member
Noticed this morning my sub seemed to be on. The blue light on the rear was lit.
Obviously I had no Av or Tv turned on. Even if I unplugged the sub cable that goes to the sub from the amp the noise was still there.
If I turned the cross over up and down on the back the noise went very loud..... like you'd expect if listening to sounds with a base.
Only way to stop it was turn the sub off.
Anyone thoughts on why it's all of a sudden started to do it. The second sub I have, which is the same make and model isnt doing it and works as it should.
Is my sub broke?
Is my sub broke?
