Q:About Direct+Sub on AV32R
Discussion in 'TAG McLaren Audio Owners' Forum' started by LJN, Apr 10, 2005.
  1. LJN
    LJN
    May 13, 2004
    64
    Sweden
    I have one AV32R BP-192 and I wonder if any on this forum use the "Direct+Sub" mode?
    How do I the configuration? I suppose I have to set the main speakers as small or not? How works the crossover settings in that mode?
    Thanks for your tips in advance!
  2. Stevesky
    Stevesky
    May 13, 2004
    454
    +13
    Direct+Sub forces the front left, right to bass limited and redirects the remaining bass to the subwoofer. It doesn't matter if you normally have your fronts declared as full range, it will still bass limit them in this mode.
    Hope that helps
    Steve
  3. LJN
    LJN
    May 13, 2004
    64
    Sweden
    Thanks Steve for your answer :) Are the crossover fr. 80hz or?
  4. Stevesky
    Stevesky
    May 13, 2004
    454
    +13
    On the AV32R SP the crossover frequency can either be 50, 80 or 125, this is defined in the subwoofer setup page. The default is 80Hz.
    The 32DP and 192R works in a different way.
