Pyramant Wireless Gaming Chair
Discussion in 'Xbox Forums' started by Rob.butters, Jan 31, 2009.
  1. Rob.butters
    Rob.butters
    Jul 19, 2007
    581
    28
    Moved from Wallington to Alaska
    +29
    Not sure where to post this thread but as it's going to be used in my sons bedroom for his Xbox 360 and not my PS3 or Wii i thought here would be a good place as any.
    I bought the wireless version of the X Rocker and have read the 'easy' to use set up instructions.....Not
    They might as well be in Swahili (sorry if you speak this language)
    Anyway does anybody know how it works, please let me know. I might take it back but my other son who is 2 have just dribbled starburst all over it.
  2. Morphies
    Morphies
    Aug 18, 2008
    818
    Rotherham
    +89
    Ok,
    How are you connecting up to the monitor?
    Presuming you are on composite / component you need to feed the IR sender from the stereo phono leads (red and white) coming from the xbox.
    In the chair pack should be a selection of cables, 1 of which will be a 0.1m female red and white phono to 3.5mm jack.
    Use the red and white phono female to 3.5mm jack to link up the red and white males coming from the xbox to the IR sender.
    Make sure the sender and chair are on the same channel and you shouldn't have any issues.
    This is of course presuming I'm looking at the right chair... http://www.xfunctional.com/Manuals/51329_XCooperIISe_080522F.pdf
  3. Rob.butters
    Rob.butters
    Jul 19, 2007
    581
    28
    +29
    Thanks for reply, i have just logged on but am watching the footie but will try your instructions out at Half time.
    I'll let you how i get on.
    Rob
  4. Rob.butters
    Rob.butters
    Jul 19, 2007
    581
    28
    +29
    Tried what you mentioned although i attached the red and white wires to the TV as i can't see them on the Xbox.
    Still not working i'm picking up a radio signal from somewhere. I am wondering if it's not working because my wireless network appears to be on the same 2.4 ghz frequency!!
    I've even tried it wired and its still not working!
  5. Morphies
    Morphies
    Aug 18, 2008
    818
    Rotherham
    +89
    How does your 360 connect to your TV?
