PYE prv 645 remote hack
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by ronnie46, Oct 31, 2005.
  1. ronnie46
    ronnie46
    If anyone finds a region free hack for this I would be very grateful.......Ronnie
  2. Demon
    Demon
    Dec 13, 2000
    1,029
    Cheltenham
    +85
    I've just tried a few of the standard philips ones, and found the usual 610 hack worked!!!
    Needs some perseverence, and quick button pressing...
    1. Turn the Recorder on using the button on the recorder itself,
    Then using the remote
    2. Press the Blue Button
    3. Press the Play Button
    4. Press 159
    5. Press 121212005255 quickly... and I mean quickly
    6. Press Play
    7. Press Standby
    It took 3 or 4 attempts, but in the end it worked, something did flash briefly on the units front display, but I didn't notice..
    I know it works, as the first disk I tried playing out of the box was Toy Story R1, which came up with the region code error... and after the hack, it now plays fine..
  3. ronnie46
    ronnie46
    Many thanks for this.......................Ronnie
  4. ronnie46
    ronnie46
    I tried and tried and just couldnt get it to work, deffo not fastest finger :( thanks anyway............Ronnie
  5. mistapaul
    mistapaul
    Nov 16, 2005
    7
    salford
    yep this hack works!
    but you need small fast fingers
    thanks peeps
    mistapaul
  6. ronnie46
    ronnie46
    If at first you dont succeed get your kids to do it for you, hack now done and working :)............................Ronnie
