px80 IR after 30min
Christoffero89
Hello. i have a panasonic th-42px80. I get IR after 30 min. I se the text line and the black line after 30 min. (i see movies in widescreen and they have black lines at the top and down.
The IR goes away fast but is it normal? 30 min is fast!
Sorry bad english
edit: the tv is 1 week old
mistymoo
what picture settings r u using (brightness contrast ....what veiwing mode is it in..cinima..eco..dynamic)????go into picture settings reset to default its at the bottom
from memory u want to set it to
viewing mode .... cinima
contrast.... 2clicks left
brightness .... 2 or 3 clicks left
color....3 clicks right
color balance....warm
color management ...off
p-nr.....off
use these for the first 200hrs then u can move brightness contrast up a bit stay well away from dynamic mode ir should lessen :clap:
Christoffero89
i have it on normal and everything is on th 50/100%
cinema i think is to grey picture:/ Normal has more color.
is my new tv broken or wil it get better? the IR goes away fast thou
rewerb
It gets better as the plasma pixels get used more. If it goes away fast it is not a problem.
Christoffero89
Thanx:D
Do you know why the green indicator light blinks a lot?
I saw it today before I went to work.
It may be that some pressure on the remote control also.
but i come back to that after i have loockd more closer at the problem:p
MrE26
I get black bar retention after less than an hour on my PX80, it washes away within minutes though & has caused me no problems, aside from minor panic the 1st time it happened.
Christoffero89
The green flash blinks after it is turn on too. it can be the remote is under the macbook and pressing som buttons. I did see it 2 minutes before i had to go for work. But i will se more on it tonight:)
is is normal that the tv is buzzing? and i hear also weary low uuuuuuuu sound. it is not loud. very low.
i see green ghosting sometimes in games but i got to say this. This is a good TV. i owns my brothers fullHD toshiba:D
