PX60 Settings Help
ingiosi27
I have surpassed the 200 hour mark, and tried embarking on improving the picture following the running in settings. I can't seem to get a better picture!!! Also, I know can't find the picture i was using for running in so am doubley annoyed!!! I only have ntl at the moment, could this be the reason the picture isn't as impressive? Any suggestions for settings, or whether I should ditch ntl would be much appreciated!!
compo
setting are a personel preference and as such you should set them how you like them. most of the disney/pixar movies have a thx setup menu on them this is a good starting point for the novice and should help you set it to a resonable picture
but don't worry about settings as you have run the set in and there should be no worries about screen burn or retention.
