Just had a quick look at mine, and there are a series of wide screw holes along both the length of the top and bottom bars.
Two of these wide holes would accomodate a 43cm width (I've just checked it with a tape measure). The product manual for the bracket is
here by the way.
Of course, whether you'd be happy with your plasma hanging of just four screws is up to you.
