PWD8 VGA Component Problem
Discussion in 'Plasma TVs Forum' started by Barton1967, Aug 26, 2006.
  1. Barton1967
    Barton1967
    Mar 1, 2004
    93
    Westcliff, Essex
    +8
    I am trying to help my friend get the best out of his setup and have come across the following problem.
    First the equipment:
    Panasonic PWD8 Plasma with composite/S-video board
    Panasonic DMR-ES10 DVD
    Pace Freesat box
    The DVD is being used as a video source, converting the RGB scart signal from the Freesat to s-video for the panel. This works as expected.
    The problem comes with trying to use the component out from the DVD to the VGA in on the PWD8. A BTech BTXL18 cable is being used and all the configurable settings I could find on both the DVD & panel have been changed to try to get component to work, but to no avail.
    Please help with any suggestions.
    Chris
    Cable link:here
  2. Jase
    Jase
    Mar 16, 2001
    10,865
    United Kingdom
    +2,902
