PWD8 Scart board v JS RGB – VGA converter
Discussion in 'Plasma TVs Forum' started by Walter Sobchak, Mar 13, 2006.
  1. Walter Sobchak
    Walter Sobchak
    Mar 29, 2005
    1,034
    +37
    Need to use my VGA input for connection to my PC. So my options are buy another VGA board or buy a scart board and sell my JS RGB – VGA converter and Van Damme 2M VGA Cable.
    How much difference between scart and my setup for connecting SKY?
    Ta.
  2. clem
    clem
    I'd also like to hear opinions on this (read on this forum that SCART board for 8 series is very good), as I'm about to buy a Scart board for connecting RGB to PWD8 (plasma VGB in use for component)
    One disadvantage of the convertor box - its another powered box to be placed somewhere on my rack/stand. Also something else to go wrong.
  3. Walter Sobchak
    Walter Sobchak
    Mar 29, 2005
    1,034
    +37
    Hmm scart boards are quite expensive @ £120
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    mep is the man to ask he has had both on his PHD8 IIRC
  5. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    Yep, I have tried them all. I found scart very good so moved the JS scart to VGA through to my PW7 where i use it for PS2. I have now got a scart to yuv converter on the PHD8, but purely so that I can switch via the 3805. I personally don't think the converter is required on the 8 series, even s-video was pretty damn good.
    Basically though I would just go for whichever route works out cheapest as you already have the js box..
  6. Walter Sobchak
    Walter Sobchak
    Mar 29, 2005
    1,034
    +37
    If like you say the svideo was good, I should maybe buy a sky box with svideo out and sell my JS box and vga lead. I would be getting cash back that way.
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    thats one reason i reconmended you got Sky+ mate
  8. mk85
    mk85
    The sky+ box costs 89quid...
    The convertor costs 130 quid
    The SKy HD box will cost 300 quid (best guess)
    Why not wait... and get the box for effectively 80 quid - which has component and HDMI output - Then its future proof.
  9. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    good point, Sky HD is worth bearing in mind, but a board will still be required.
  10. mk85
    mk85
    what about an amp that does switching....
  11. mk85
    mk85
    if youre getting an amp.... just get one that switches... rather than a scart board. From what i hear, the scart system is becoming redundant....
  12. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    a switching amp is great but one that does component and hdmi is a different ballpark cost wise to the other options.
  13. Walter Sobchak
    Walter Sobchak
    Mar 29, 2005
    1,034
    +37
    tbh I was thinking of scrapping sky and buying the freeview box with hd. As I no longer subscribe to sky, just use it for the free channels.
  14. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    ah well in that case if you go for a toppy you can connect component to plasma, MAW has this up and running and thinks its very good
  15. nheather
    nheather
    Oct 6, 2004
    19,717
    167
    Horsham, West Sussex
    +9,993
    I feed Sky+ into my PHD8 using S-Video. In my opinion the picture is excellent - certainly good enough to persuade me from buying extra bits such as SCART boards or convertors.
    I switch my S-Video through my amp for a couple of reasons
    (i) My amp has on-screen setup (which is very useful) but is only supported on S-Video. So if I want on-screen setup I have to share my S-Video input between Sky+ and the Amp.
    (ii) I have an easy route to connect auxillary bits of kit (like cameras) - just connect to front of amp - so fiddling behind the kit or disconnecting anything.
    Cheers,
    Nigel
