PWD8 How long is cable?
Discussion in 'Plasma TVs Forum' started by yeff, Oct 21, 2005.
  1. yeff
    yeff
    Oct 25, 2004
    54
    Hi, after many months of looking on the forum have finally ordered a PWD8 :clap: Will be plastering cables into wall over weekend, so was wondering what the length of the power lead is as nearest socket from where screen is going is 4 metres away in corner of pic.
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Not that long!
  3. bigtired
    bigtired
    Nov 1, 2003
    160
    North Wales
    Its about 2 metres
  4. yeff
    yeff
    Oct 25, 2004
    54
    Thanks for info, looks as if will have to put a new socket a bit closer.
  5. av2diefor
    av2diefor
    Why not fit a fused spur in the vacinity,then run a 1.5mm cable to the back of the plasma behind the plaster?
  6. yeff
    yeff
    Oct 25, 2004
    54
  7. Parklife
    Parklife
    Jun 9, 2004
    574
    28
    +33
    Just get a fused spur in if you can. When you get the cord with the plasma cut the plug off and wire it into the spur. You could also just get an IEC kettle type lead and get it all set up ready.
  8. yeff
    yeff
    Oct 25, 2004
    54
    So will I just put fused spur @ back of screen?
  9. av2diefor
    av2diefor
    If it was me mate, put a fused spur low level(near the floor).
    Then run a piece of flex or twin &earth cable to behind the plasma into another box (sunken).
    This then gives you a connection to the plasma lead and can be isolated.
  10. yeff
    yeff
    Oct 25, 2004
    54
    what side of panel is power socket? as putting fused switch in tomorrow.
    Also is it ok to just cut plug off the lead?
  11. Piers
    Piers
    Dec 11, 2002
    1,995
    Cheshire
    +230
    Power socket is on the left hand side of the panel as you look at it from the front.
  12. yeff
    yeff
    Oct 25, 2004
    54
    Thanks Piers.
  13. vileda
    vileda
    Oct 15, 2004
    401
    Sunderland, Tyne & Wear
    Page 16 of the pdf on this page here at AV-Sales will have everything you need measurement wise.
